ArubaOS and Controllers
Frequent Contributor I
API for automated settlement for Guestaccounts
Hi
Does anybody know, if there is a possibility, such as an API to connect the guest user database to SAP?
We want the system to produce automated settlements for the use of guest accounts.
Does anybody do something similar?
Thanks for your support.
Florian
Re: API for automated settlement for Guestaccounts
There is a XML-API that can add/delete, change the role and query the status of users. Documentation is attached.
thanks, but i think it is not what i'm looking for.
I do not need to modify guest users.
I only need to get information about the duration of the useraccounts for a specific period of time.
A table like:
User1 Start:08/22/2011 End: 09/22/2011
This data should be provided every month and it should be exportet or reachable from other systems.
any idea?
The best way that you can do that is via radius accounting. There are a number of software packages that interpret radius accounting information from the controller and provide the reports you desire. Alternatively, Aruba's Amigopod product can provide this information.
