ArubaOS and Controllers
APs switching to AMs with clients connected
Question, in one of my sites I see APs switching to AMs (mode aware enabled) when clients are connected to the AP in question. I also see AP to AM switching a bit too frequently. Meaning one is an AM for an hour, then it switches back to AP and a neighboring AP becomes and AM for a bit, then other. Any ideas?
EDIT: Running AOS 3.3.2.19.
Re: APs switching to AMs with clients connected
Secondary question. Is there any way I can see why a client was moved from one AP to another?
There was a recently fixed bug concerning AP125s specifically and Arm Mode-Aware in ArubaOS 3.3.2.20
User-debug
The client still makes the majority of decisions. If you use user debug, it will say that the client moved, but the client itself never says why.
Thanks Colin. This site has all 65s, so I'm not sure it was the bug. I'll be sure to do the debug next time, but I found two things. First, the user's driver was very old, second, Station Handoff Assist was turned on without any of its thresholds being set. SHA is now off, like it should be, and the driver was updated. Didn't observe any more bouncing around.
