ArubaOS and Controllers
Frequent Contributor I
Active Controller Summary
Is there a command to display all active controllers on the network? including serial numbers?
Aruba
There is a multi-step method to obtain this information:
a) When logged into a controller via SSH, the CLI command "show
switches" will provide a list of all controllers in the Master--Local
cluster. It provides IP address and not serial number information for
each controller. The WEB UI provides similar information under
Monitoring/All WLAN Controllers.
b) When logged into one of the controllers from the list above via SSH,
the CLI command "show inventory" will provide serial numbers of that
given controller. The WEB UI provides similar information under
Monitoring/Inventory
Re: Active Controller Summary
Thanks, got the info I needed
