Android, 802.1x
HI, MY CUSTOMER IS HAVING PROBLEMS TO CONNECT SMARTPHONES
Brand: Samsung
Model: Modelo Galaxy Mini
Android, ver.2.2.1
TO ACCESS Skype, Viber, WhatsApp, Internet AND INTERNAL NETWORK WITH 802.1X. ALL LAPTOPS, IPHONES AND IPAD´S WORK FINE.
DO YOU KNOW WHAT COULD BE HAPPENING AND IF THIS KIND OF SMARTPHONES ARE SUPPORTED?. ANY HELP OR SUGGESTION WILL BE APPRECIATED. THANKS
Re: Android, 802.1x
What version of code is the customer running?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Android, 802.1x
3.4.1.0 on 3200
Re: Android, 802.1x
I have a 2.3.4 Android device connected to my controller (6.1.2.2) just fine.
Turn on debugging for the MAC address of the phone (CLI -> "logging level debug user-deubg xx:xx:xx:xx:xx:xx", then retry the connection. Then, do a "show auth-tracebuf" and "show log user-debug all". If you dont see anything obvious in the logs or auth-tracebuf, paste the output here and we will take a look at it.
Re: Android, 802.1x
There's a bug in Android version 2.2 which might be causing this issue.
Source
Is it possible to test an Android phone on a different OS version?
Cheers
James
Re: Android, 802.1x
You can try unchecking "Firewall Prevent ARP spoofing" to work around the issue for now.
config t
no firewall prohibit-arp-spoofing
There is an issue that was fixed in ArubaOS 3.4.5, where Android OS cannot pass traffic if prohibit-arp-spoofing is enabled.
Proxy
I found that customer has a proxy server and content filter for internet access. The problem arise as some android phones are not able to configure a proxy server. And for the web content filter where necessary to add phones ip´s in order to access internet w/o restrictions. Thanks again to everyone. Now the problem was found and will be take care of it.
