Occasional Contributor I
Anyone using WoWLAN
Has anyone configured WoWLAN? If so, did you have to make any configuration changes on the controllers to make this work?
Jason
VoWlan
Jason
Golecj,
Different manufacturers require different parameters for each handset. If you contact support, they can provide those for you.
Colin Joseph
Aruba Customer Engineering
Re: Anyone using WoWLAN
One of our engineers reported that he has this working on his Lenovo T400, but as Colin suggested you'll need to make sure your NIC supports this.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
I am referring to Wake on Wireless LAN. I think you might be referring to Voice over WLAN.
THanks,
Jason
Jason, we may have crossed posts, but I was also talking about wake on WLAN, which is a matter of support on the NIC you are using. Our engineer has his laptop being woken up by his backup server on the same VLAN.
-awl
Andy Logan, ACDX
Aruba Networks
