ArubaOS and Controllers
Are people having problems with the newer 2048 CSV
This initial issue has to do with Captive portal.
We have recently gotten a certificate from Comodo. When we open the browser we get an invalid security certificate warning. I've been told by tech support that the controller does not support the 2048 bit value for the trusted CA chain installed on the controller.
What CA are you using to maintain the 1024 bit value for the trusted CA chain?
Thank You
