ArubaOS and Controllers
Aruba 2400 Controller Serial port Question
Hi, I m recently doing some training on our Aruba 2400 Controller that is a lab device. I tried to connect it using Console cable ( the cisco one + Usb covert) by my laptop. After reboot the controller, I can see booting information, but when the Username promp, I couldnt type any char; I tried reboot and stop autobooting by any key, still not work. So now I couldnt login that controller, either from web UI ( no idea what IP address it is using )
Anyone know what the problem is ? how can I fix that ??
thank you ~~~
Re: Aruba 2400 Controller Serial port Question
no flow control.
ty , i will test it later .
