ArubaOS and Controllers
Aruba AP - wired dot1x client
We would use the rogue AP feature on our aruba controllers.
For this we understand that rogue AP must be seen on the wireless and wired side. To do this we have to configure the switch port connected to an AP in trunk mode.
But this config put some security problems : some wall port which are connected AP are visible and someone could plug in place of the AP and access to unwanted networks.
So is there a way to secure the connection of an AP on the wired network (802.1X client for example)
Thanks in advance
