ArubaOS and Controllers
Aruba Controller Configuration - Best Pratices
I'm looking for some type of Best Practices for a general Aruba Controller config.
cheers,
Aruba
As a starting point, I would recommend that you review the Reference Design Guides located at: http://www.arubanetworks.com/technology/reference-design-guides/
Re: Aruba Controller Configuration - Best Pratices
Thanks for the reply.
I did a Google search and found that too. I'm looking for some other type of resource.
cheers
-netcat
What type of resource are you looking for? Also, what features/functionality are you looking for...?
