ArubaOS and Controllers
Frequent Contributor I
Aruba S3500 switch - Do Configuration on Aruba Controller
Who have user guide do the configuration on Aruba Controller then push the config to Aruba S3500 switches?
Because i need to know how Aruba Controller manage the Aruba Switch for example, assign the VLAN based on user role instead of using the switch port assign the VLAN.
Thanks & Regards,
Tin
Re: Aruba S3500 switch - Do Configuration on Aruba Controller
The Aruba controller cannot push configuration to the S3500 switch, yet.
You need an Aruba Controller on Version 6.1.x.x
You need an S3500 Switch on Version 7.xx
Download the 3500 user guide here: http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=5910
Go to chapter 8 in that document called "Tunneled Node". That chapter describes how to configure what you want.
At the moment what Aruba controller can do with the Aruba switch? Beside Tunnel mode.
How about the based on user role assign VLAN? Because traditional way like Cisco is based on switch port.
Please take a look at the document here: http://www.arubanetworks.com/wp-content/uploads/TB_S3500.pdf
Hi all
I checked "Tunneled Node" in chapter 8 and i did the configuration in the switch. But the tunnel is down.
Below is what i did
Controller
interface vlan 1000
ip address 192.168.170.1 255.255.255.0
operstate up
ip dhcp pool VL1000-controller_tunnel
default-router 192.168.170.1
network 192.168.170.0 255.255.255.0
authoritative
switch S3500
vlan "1000"
description "controller_tunnel"
interface-profile switching-profile "controller_tunnel"
access-vlan 1000
interface-profile tunneled-node-profile "controller_tunnel"
controller-ip 192.168.170.1
interface-group gigabitethernet "controller_tunnel"
apply-to 0/0/1-0/0/4
can you provide me a working configuration.
if you can post a good documentation it will be fantastic
A few questions:
Can the switch ping the controller?
On the 3500, please execute the following:
show tunneled-node state
show tunneled-node config
show vlan
On the Aruba Controller, please execute the following:
show vlan
yes it can
show vlan
(ArubaS3500-24P) #show tunneled-node state
Tunneled Node State
IP MAC Port state vlan tunnel inactive-time
192.168.168.50 00:0b:86:6a:bf:00 GE0/0/1 not-started 1000 4094 0000
192.168.168.50 00:0b:86:6a:bf:00 GE0/0/2 in-progress 1000 4093 0000
192.168.168.50 00:0b:86:6a:bf:00 GE0/0/3 not-started 1000 4092 0000
192.168.168.50 00:0b:86:6a:bf:00 GE0/0/4 not-started 1000 4091 0000
(ArubaS3500-24P) #show tunneled-node config
Tunneled Node Client: Enabled
Tunneled Node Server: 192.168.168.50
Tunneled Node Loop Prevention: Disabled
(ArubaS3500-24P) #show vlan
VLAN CONFIGURATION
VLAN Description Ports
1 VLAN0001 GE0/0/0 GE0/0/5-23
1000 controller_tunnel GE0/0/0
4091 MUX Internal VLAN
4092 MUX Internal VLAN
4093 MUX Internal VLAN
4094 MUX Internal VLAN
show vlan
(Aruba620) >en
Password:********
(Aruba620) #show tunneled-node state
Tunneled Node State
IP MAC s/p state vlan tunnel inactive-time
(Aruba620) #
VLAN CONFIGURATION
VLAN Description Ports AAA Profile
1 Default FE1/0 FE1/2-7 Pc0-7 N/A
3 VLAN0003 GE1/8 N/A
20 VLAN0020 N/A
40 VLAN0040 N/A
50 VLAN0050 N/A
60 VLAN0060 N/A
70 VLAN0070 N/A
88 VLAN0088 N/A
121 VLAN0121 N/A
123 VLAN0123 N/A
124 VLAN0124 N/A
128 VLAN0128 N/A
177 VLAN0177 N/A
200 VLAN0200 N/A
1000 VLAN1000 FE1/1 N/A
The VLAN used for this configuration is the VLAN 1000
Just saw this in the release notes:
"ArubaOS 6.1.2.1 does not support tunneled-node with the S3500.
Workaround: Best practices recommend that you do not upgrade to this release if your topology includes a S3500. ArubaOS 6.1.1.x supports tunneled-node with the S3500."
Please use an earlier revision of ArubaOS if you are running 6.1.2.1 for tunneled node to work.
If I already upgrade the firmware from 6.0.1.1 to 6.1.2.1 still able to downgrade it 6.1.1.0?
Because currently Partition 0 is default boot and running 6.1.2.1 and Partition 1 is installed 6.0.1.1.
Please advise.
Please use 6.1.1.0 under archived software
