ArubaOS and Controllers
Aruba Vlans and Dell Switches
My whole network is built on Dell Powerconnect 6224P and 6248P switches, I'm trying to change my network in multiple VLANs but when I try to connect a port defined as trunk from Aruba 6000 to pass all VLANs traffic to a Dell Switch, nothing passes through. (Dell switch also has the port defined as trunk with same VLAN IDs).
If I use the ports in access mode they both recognize the Vlan assigned.
Anyone has knowledge on VLANs with Aruba and Dell Switches ?
Help would be greatly appreciated,
Aruba
I have many deployments with Dell LAN <--> Aruba controllers.
What does the configuration of each side look like ?
Re: Aruba Vlans and Dell Switches
Configurations are as follows:
I had defined VLANs 10-16, 21-26, 31-33 in both Aruba and Dell.
Aruba 6000:
interface gigabitethernet 0/10
description "XG0/10"
trusted
trusted vlan 1-4094
switchport mode trunk
no spanning-tree
Dell 6224P:
interface ethernet 1/XG1
channel-group 10 mode auto
exit
interface port-channel 10
switchport trunk allowed vlan add 10-16,21-26,31-33
switchport trunk allowed vlan remove 1
exit
Aruba
So one side is a port channel and the other is a standard trunk ?
I would have pursued something like this on the Dell side:
console(config)# interface ethernet 1/XG1
console(config-if)# switchport mode trunk
console(config-if)# switchport allowed vlan add 10-16,21-26,31-33 tagged
console(config-if)# exit
Have you tried this style of config to 'match' whats on the controller side ?
No, I have not try this style.
I will try this configuration and let you know.
Thanks for your help.
Aruba
Anytime.
Good luck. ;) and if it still doesn't work from there we can debug further of course...
Alfspace98,
did you have any luck with this? I am having the same issue with a dell 6248 and an aruba 3400 controller.
Aruba
Alf,
Do you want to post your configs here as well ?
Likely will help move this along.
