ArubaOS and Controllers
ArubaOS 6.1.2.2 How will i to do disable Rogue AP ?
I use ArubaOS 6.1.2.2 (Digitally Signed - Production Build) 29541
I want to disable the rogue ap but i don't see menu to disable
Re: ArubaOS 6.1.2.2 How will i to do disable Rogue AP ?
The "Contain Manually" button should be able to do this on the Dashboard.
