ArubaOS and Controllers
ArubaOS 6: srcnat issues
as with previous versions i tried to configure srcnat in ArubaOS 6. I can't do srcnat for whole VLANs (in the IP configuration) due to some other requirements. So i tried to configure it within the user roles/policies. But every time i configure such a rule it just vanishes after applying.
Has anybody the same experience? Is srcnat deprecated? Is it a bug? Is it expected behaviour?
I found nothing in the docs nor in the knowledge base.
Grateful for any hints,
Re: ArubaOS 6: srcnat issues
This could be a bug. Right before you click "apply", click on the "show commands" button to see what will be applied. Also go on the commandline and type "show audit-trail 10" to see what was typed after you click apply.
If it is inconsistent, please open a case so that it can be replicated and fixed.
Colin Joseph
Aruba Customer Engineering
it's a bug
Hi cjoseph,
yes, really. It's a bug. The GUI only lets you enter CIDR masks ("24") and reports error when entering Whereas the CLI needs the latter.
I'll open a case.
Best regards,
It's a bug. I reported it back in early Janurary. It exists in and I haven't tried to see if it's fixed in yet. The bug ID is 48894.
