ArubaOS and Controllers
Contributor I
Auto sign in for wifi printer?
I have a guest wireless network and authenticate with captive portal. This network is strictly for customer only. In some occations, they bring in wifi printers. The printer itself can't auto browse to the captive portal and enter credential. Is there anyway, we can manually enter printer into the database and allow auto authentication? :confused:
Aruba
Sure, you could do a ""user derivation rule"" (user rule) in the WEBUI to take the MAC of the printer and 'promote' it up to a role that bypasses the captive portal when its detected on the network.
