ArubaOS and Controllers
Occasional Contributor I
Automatic provisionning for captive portal
Dear all,
Our goal is to provision a new generic account every sunday (or to change the password of an existing account).
The new account (or password) will be given to authorised people and will be valid for a week.
Is there a way to automate this ?
Thanks in advance
Emmanuel
Kiwi
You can use Kiwi Cat tools to run the "local-userdb-guest-add" command and turn on SMTP on the controller to email the username and password: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=897
Re: Automatic provisionning for captive portal
Hello CJ,
So the solution is partly outside the product itself.
Thanks a lot for the quick solution.
Emmanuel
Yes
Correct.
Frequent Contributor II
We have a similar requirement in which our auto-provisioned guest account changes daily.
To do this we created the guest account in our Active Directory and added our IAS Servers to the server group for Captive Portal authentications.
To change the password we created a script that runs once per day on the IAS server. The script changes the guest user password and emails the new password to our client support center.
Script
Tpelly,
Is there any way that you can post that script for the benefit of the rest of us?
Thank for the info.
Though I will use the internalDB for the captivePortal Logon and I will schedule a ssh command to the controler. Something like :
Another possible way is to create in advance many users with successives start and stop dates. This way I can batch create 52 users, one for each week for example.
Tpelly,
I will have to do a little editing to remove the "naughty bits" but will post a copy in this thread.
Update: the script is attached. Please keep in mind that I am not a Visual Basic programmer and did not write this script. I was written by the individual that manages our Active Directory accounts. In all likelihood I will be unable to answer questions related to the VBS programming within the script.
