ArubaOS and Controllers
Bridging LAN and WLAN networks
I udnerstand there is a setting on the Aruba switch somewhere that allows you to disable bridging. In other words, if someone is cabled into the corporate network and then attempts to associate with an Aruba AP the Aruba switch will not allow the wireless session. Has anyone used this/heard of this?
Thank you
