ArubaOS and Controllers
Super Contributor I
CLI command to verify Ethernet connectivity
All,
I'm having a hard time finding a CLI command. How would you go about seeing wired interface stats on a campus AP or a RAP? I'd like to verify that our campus APs (AP-125s) and RAPs (RAP-5WN) are using the properly configured Ethernet ports.
Thanks!
-Mike
Re: CLI command to verify Ethernet connectivity
http://airheads.arubanetworks.com/vBulletin/showthread.php?t=761
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Super Contributor I
Colin,
As always, thanks for the spot-on help! Here's what I found for the RAP5:
Ethernet Duplex/Speed Settings
Autoneg Speed (Mbps) Duplex Iface
on 1000 Full eth0
on 10 Half eth1
on 100 Full eth2
on 100 Full eth3
on 10 Half eth4
Running the following will bring you right there:
show ap debug system-status ap-name | begin Autoneg
Any connected device should be associating at 100/Full, so this is a quick way to verify connectivity.
Thanks!
-Mike
Airwave also can display this information quite nicely:
