ArubaOS and Controllers
CODE MERGING RN and 3.4.X
HI is there any date yet for the merging of the RN code with the Standard 3.4.X code so that we can run both RAP2WG and Enterprise AP's ? on the same controller
Next Major Code Version
If you speak to your local Aruba representative, they should be able to give you guidance.
Yes, that is me saying I do not know....
Thanks Colin
According to my rep the merge is supposed to happen in 3.5.x which is due "Mid-February". Maybe they thought February was longer......
Aruba
To help you to the same page, there is no AOS 3.5.x so it certainly
won't be out in February :)
The merge will occur in AOS 5.0 which is in Beta presently.
As for dates of General Availability, the guidance passed along earlier
is best: work with your local representative to plan for migration that
makes
the most sense for your environment, goals and requirements.
JF
