CP on GRE interface
I'm terminating a GRE-Tunnel from an small Cisco router on my controller and want to terminate users routed through it by Captive Portal. So, what I did was to trust the physical interface (and the used vlan on it) and instead untrusted the tunnel interface.
This causes some problems, since the user gets terminated correctly, but instead of the welcome page, he gets the page cp_disabled.html saying "Web authentication is disabled".
If I shutdown the tunnel and route the exact same traffic on a physical interface (which I untrust for that test), the same configuration perfectly works and I get to the CP-welcome page...
I'm using 3.4.1.0... Any ideas?
Untrusted
Beat,
Any user on an "untrusted" port or tunnel ends up in the initial role of the AAA profile that is configured at Configuration> Wired Access> AAA Profile. The default initial role is "logon". You will see the "Web authentication is disabled" message, if there is no Captive Portal profile configured in the "logon" role. Edit the logon role and add a captive portal profile to it in configuration > Security> Access Control > Edit the Logon role and select a Captive Portal Profile.
I'm saying to edit the logon role as a quick solution to your problem, but the best practice is to clone the logon role, clone the default AAA profile and use and edit those.
Re: CP on GRE interface
Hola,
The good news: It worked with adding my captive portal to the logon user role...
But I checked the config and the controller is not supposed to use this role and the role is not mentioned to be referenced anywhere in my config...
I also changed the existing AAA profiles to go to the initial role I defined to find out which one is actually in use... But even when I changed all of them, the logon role got used...
This is the config I was using (And which works on physical interfaces):
aaa authentication wired
profile "Guest_AAA"
aaa profile "Guest_AAA"
initial-role "Guest-logon_UR"
no wired-to-wireless-roam
user-role Guest-logon_UR
captive-portal "Guest_CP"
session-acl Guest-logon_ACL
Any idea where the root of this could lie? Just a software-bug?
Thx & Greetz
When the user has associated to the system and you issue a 'show user' on the CLI before they authenticate it's saying they are in logon and not the guest logon role you created? You do have a CP profile configured for the guest role, so they should see the CP:
captive-portal "Guest_CP" <<<
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Jep, the user shows up in the logon-Role:
Users
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile
10.231.248.2 00:0b:86:0d:64:00 logon 00:00:00 N/A
Thx & Greetz
Beat
