ArubaOS and Controllers
Campus wide plan and heat maps
We're in the early stages of a campus deployment with about 120 APs in ~20 buildings, with up to 20 AP-124s and outdoor antennas for outdoor coverage. Controller is a 6000 running 5.x OS. Airware is not part of the package yet, although it may be soon. Is there a way to map the entire campus, rather than just buildings, so we can see outdoor heat maps as well?
Contributor I
Re: Campus wide plan and heat maps
I can't see a problem as long as you can import a map of the campus and include the size info.
The caveat being that I can't think of a way to have one ap in two maps. So you would need an AP group or Aps placed apart from in building APs.
A "rooftop" group would work fine. They would appear on the rooftop map.
Frequent Contributor II
I don´t get it at all!! :confused:
We have similar issue, since 2004 :p, we have more than 200 APs 60,61,70 model and some 85 Models but our campus have more than 80 Buildings with concrete walls:eek:, so we need something similar. We are waiting for a "better" aruba/airwave support....
By the way: Spanish Welcome. ;)
We have been asking for this for a while. I hear it's coming though!!
Best to file an RFE with your account manager.
