ArubaOS and Controllers
Can Fail Through work across 2 Domain in other site ?
If don't terminate 802.1x (EAP-PEAP, EAP-TLS) on Controller, Can Server Group Fail Through work with 2 domain in other site ?
If it can How should I do in 2 Controller and 2 Radius in other site ?
PS.I want to authenticate user & authen certificate
Re: Can Fail Through work across 2 Domain in other site ?
Fail through can only work when there is termination enabled, period.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Can Aruba authenticate with User Authentication and Client Certificate simultaneously in 802.1x?
I don't sure that mean LEAP on Cisco-Propietry. or Aruba can do this requirement ?
Thank you
It is up to the client to submit both computer and user credentials, and most clients do not do that. The closest you can get to this is by using enforce machine authentication on Aruba.
Machine authentication can spoof, so I want to identity client with user authentication credential and verify machine with client certificate (client cert).
Is it possible ??
If you use TLS, that will address all of your issues.
