ArubaOS and Controllers
Can change color and position on acception page on captive portal?
aruba controller OS 3.4
Change Position
Super K,
You can do this by uploading your own custom HTML to the captive portal profile. There is not a way to do it through regular controller configuration.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Can change color and position on acception page on captive portal?
cjoseph,
Can you suggest about html code to change color and position acception page and how to upload?
Change Position
cjoseph,
Super K
Support should be able to give you suggestions about this.
