ArubaOS and Controllers
Occasional Contributor I
Can't login to webgui of controller efter reset admin and enable passwords
Hello Guys,
Would really appreciate if someone can help me out. I recently changed passwords of admin and enable under command line. I wrote to memory and reload the switch. After that, everything else is working fine. However I cannot login to webgui of aruba controller anymore. What can be the reason?
:confused::confused:
Re: Can't login to webgui of controller efter reset admin and enable passwords
Moved this over to the ArubaOS and controllers forum.
From this I'm guessing you can still login via serial and SSH. If so you probably want to check which special characters you used in your admin password, such as a percentage sign, most likely they are being interpreted as an HTML character in the WebUI.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
You Rock Andy!
I did use % in the password. I changed it and now it works. :)
Thanks!
Glad that worked for you.
-awl
Andy Logan, ACDX
Aruba Networks
