Occasional Contributor I
Captive Portal Issue
I've configured a SSID for guest users. PEF license is installed on the controller (Aruba-800) with OS version 3.3.2.21. Whenever I try to open internet explorer to get captiveportal then the attached error comes.
Please help me to solve it.
Captive Portal Authentication Profile
Askmcse,
you get that error when there is no Captive Portal Authentication profile attached to the user's logon role. When the user gets an IP address from the WLAN, do a "show user" or look in the user table and see what role he/she is in. That is the role that you need to go to configuration> Security> Access Control> Edit . Go down to Captive Portal profile and change it to a captive portal profile to allow that user to authenticate via captive portal.
Colin Joseph
Aruba Customer Engineering
Captive portal issue
Askmcse,
Let me try
Thanks in advance
Reg
Let me try
Thanks in advance
Reg
Hi
Its working now, thanks again
Reg
Faisal
