ArubaOS and Controllers
Contributor II
Captive Portal not working when using RAP
I configured 2 captive portals, one is accessible via dedicated SSID (GuestWLAN) and one is accessible via a wired port on a RAP. The captive portal that is linked to the RAP does not show.
The RAP comes up OK and if i connect a laptop to the right port i get an ip in the expected network, but when i start browsing dont get the captive portal. Default behavior would be to redirect the user to the captive portal on the controller using HTTP 302 status code, somehow it doesn't redirect to the controller but to the requested URL, resulting in an endless loop.
Re: Captive Portal not working when using RAP
Did you make the port for the AP untrusted?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
yes, the port is untrusted.
When you look on the controller, what is the role that the user is in on the wired port? On the commandline, please type "show rights " to see what firewall policies that user has.
Contributor II
The role assigned is gamezone-logon:
192.168.111.190 00:25:64:62:2a:39 gamezone-logon 00:00:00 GDF-RAP04 Wired 192.168.114.17:0/1 gamezone tunnel Win 7
This role has the following ACLs:
1 logon-control
2 captiveportal
3 v6-logon-control
4 captiveportal6
Contributor II
Bump!
Please open a case. This could be very complicated.
