ArubaOS and Controllers
Cascading Aruba 3200 controllers: is it possible?
can someone help me out. I am thinking of cascading 2 3200 controllers since i need to connect above 32 LAN connected AP's. Is it possible to cascade 2 3200 controllers?
Re: Cascading Aruba 3200 controllers: is it possible?
Yes it is possible.
You can make the second 3200 a "local" of the first and then use ap-groups to decide what access points connect to what controller.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Take a look at the mobility controller and deployment model VRD available at http://www.arubanetworks.com/vrd, that will help you understand the deployment model options. If you haven't purchased the gear already you might consider upgrading to the 3400 which has a larger AP capacity.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
