ArubaOS and Controllers
Certificate not used for 802.1x
Dear Sirs!
I'm using Version on 3600 controller.
I just installed a server certificate as described here:
If the link does not work. It is answer id 772 in kb.
My new (own) certificate (with appended certificate chain) is used+shown+accepted by all clients on captive portal and WebUI-authentication.
BUT: with 802.1x authentication (termination on controller) still the build in certificate is presented to the clients.
I also did already reboot the controller without success.
What's wrong?
Re: Certificate not used for 802.1x
Answer from support:
certificate for 802.1x is only supported with 1024 bits :mad:
