ArubaOS and Controllers
Occasional Contributor I
Certificate problems with WPA2-PSK
I'm running 5.0.3.3.
If I configure a SSID with WPA2 Enterprise.
AAA inital role: logon
AAA 802.1x ... default role: authenicated.
Everything works great.
If I configure an SSID with WPA2 PSK.
I get connected, I can ping things on my network and internet but certs get messed up. When I browse to google or any internet site I get sent to:
https://securelogin.arubanetworks.com/auth/cp_disabled.html
It appears that a securelogin.aurbanetworks.com cert is installed on my PC (Win7) and I'm hosed, I lose all AD authentication, Outlook can't connect to exchange.
If I reconnect to the SSID that uses WPA2 Enterprise. Then everything is back to normal.
AAA inital role: authenicated
Then I don't get the errors.
What is going on?
Is it ok to leave the roles Authenicated/Authenticated?
BTW the logon and authenticated roles are the defaults that come with the OS.
Mike
Re: Certificate problems with WPA2-PSK
Change the initial role to authenticated. The logon role will force the user to authenticate via captive portal.
To elaborate on cjoseph's answer, the reason you change the initial role on the PSK SSID is because technically knowing the PSK *IS* your authentication, as a result, the initial role is post-PSK-auth, and will be the role the users get.
Jerrod Howard
Contributor I
Hi All,
I have the same problem but my SSID profile use MAC+Captiveportal.
Sometime, the client passed authentication and get authenticated role but the controller alway redirect client to "Page web authentication disable" which shown below. If i disconnecting and reconnecting again the problem gone.
It's happen unpredicable and I don't know how to track this problem.
Any idea?
