ArubaOS and Controllers
Changing encryption increase throughput?
We have an old ssid that uses WPA-TKIP for encryption. We have upgraded our APs to the 105-N, but we're still only getting G speeds. If we configure the SSID for the new encryption we will lose connectivity to 100 plus wireless carts throughout the hospital. First, will we see N speeds with the new encryption and secondly, what's the best way to migrate without impacting patients?
Re: Changing encryption increase throughput?
For your older devices that must do WPA-TKIP, you can run in mixed-mode WPA-TKIP and WPA2/AES (configurable under the advanced tab on the SSID profile). Your WPA-TKIP devices will only be able to do 54, while your 802.11n devices that do WPA2-AES can do much higher.
The standard requires WPA2/AES encryption or Open to do 802.11n speeds.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
