ArubaOS and Controllers
Occasional Contributor I
Cient Timeout Question
Our help desk group has requested access to clients systems under the following conditions so that they can perform updates or gain remote access
*clients that connect to an ssid but do not login
*clients that were connected but have logged out
I have set the timers below but they are still reporting issues
aaa timers idle-timeout 0
aaa timers logon-lifetime 0
Under the wlan ssid-profile setting
ageout 86400
For the clients that connect to an ssid but do not login, they havve completed a machine authentication but have not user authentication. They are ok for 10-18 minutes but then stop responding. Does anyone know of any other timers that affect this.
Thanks in advance
What kind of encryption are these clients using?
Colin Joseph
Aruba Customer Engineering
