ArubaOS and Controllers
Occasional Contributor I
Clients are not communicating each other
Hi
we are using 3400 controller with 6.1.0.0 code. Everything is working file but only wifi clients on the same ssid aren't able to communicate. All ap-93 are configured in rap mode.
info: deny inter user traffic is not enabled... no pef lic is installed...
suggestions are invited
thanks
rk
Re: Clients are not communicating each other
Is the Virtual AP in tunnel mode?
What are the ACLS on the role that the clients get into (show rights )?
Frequent Contributor I
Perhaps you may like to check if you have a rule something like the below:
user "internal-networks" deny...
all wlan clients will not be able to connect to each other...
Cheers,
Michael
VAP is in tunnel mode and
no acl is applied as there is no policy enforcement firewall installed.
cheers,
rk
There is a known issue in 6.1 software. Do the command "firewall prohibit-ip-spoofing" from the CLI and that issue should go away.
Sorry... command should be "no firewall prohibit-ip-spoofing". Not enough coffee this morning!
Thanks, it works.
