ArubaOS and Controllers
Configuration Documetation for controllers
Hello all,
I am new to the Aruba world of wireless. I have done a lot of Cisco in the past and now I am starting to work with Aruba. Does anyone know how I can get some configuration docs on Arubas controller?
Thanks KK
Docs
Hello all,
Thanks KK
Kickman,
The complete ArubaOS userguide is under the support site under documentation. Base configuration documents for setting up a base Aruba Controller is on the technology page here: http://www.arubanetworks.com/pdf/technology/DG_WLAN_Base_Configuration_ArubaOS31.pdf
Colin Joseph
Aruba Customer Engineering
Re: Configuration Documetation for controllers
Thanks thats what I needed!
I would also recommend you take a look at the validated reference design series, it has deployment designs and configuration settings for various deployment types.
http://www.arubanetworks.com/technology/design_guides.php
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Video
-awl
Also take a look at this Video by Jon Green, on the Education Page, on setting up an Aruba Controller: http://www.arubanetworks.com/education/controller_setup_video.html
Colin Joseph
