ArubaOS and Controllers
Frequent Contributor I
Confinguring IP range in ArubaOS
Hi All,
Anyone know how to configure an IP range 10.1.0.0 to 10.100.255.254 in ArubaOS Stateful Firewall>Destination?
Michael
Range too Big
Michael,
You cannot assign a "range" bigger than a /16. Try to use the "network" parameter to break up that range of addresses.
The underlying reason is that behind the scenes, when you do a range, the policy is expanded and rewritten for every single ip address for that range, which takes up a great deal of space. Use "network" when you can to workaround this limitation.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
ok
Thanks Colin!
