ArubaOS and Controllers
Connecting wireless device/server using a wireless bridge?
I have an Audio/Visual server that does not have a wireless card slot. I am trying to use our existing Aruba wireless infrastructure to extended the A/V's wireless handheld controller. I am going to connect an ASUS WL-330gE in repeater mode to the server and create a separate SSID specific to this installation. Is anyone familiar with this type of installation? If so what is the Aruba speak for this?
Questions:
-If I create a VLAN/DHCP scope do I still have to relate it to a port on the controller even though I am not utilizing any ports on the controller?
-How would I best secure this type installation? ACL's make the most sense.
