ArubaOS and Controllers
Controller 3400 & AP175 installation
Hi guys,
sorry but i'm pretty new on the Aruba world, i have a 3400 controller with ArubaOS 5.0.3.3 installed and i've connected an AP175 to GE1/0 port but i can't see the AP.
I run the initial setup with dhcp server enabled and i had licenses installed too.
So, what's the problem? I should be see the AP in the AP Installation>AP Campus whitelist or maybe into AP Wizard setup??
thanks!!
leighton
Re: Controller 3400 & AP175 installation
Is the AP getting an ip address from the controller? Do a "show ap database" to see if that access point ever contacted the controller. Also, do a "show ip dhcp binding" to see if it might have gotten an ip address. Can you plug a wired client like a laptop into the controller and get an ip address?
