ArubaOS and Controllers
Controller 620 was reboot : Reboot Cause: Datapath timeout.
help me please....
My controller 620 was reboot
i use command " show switchinfo " and found error
ArubaOS (MODEL: Aruba620), Version 6.0.1.2
Website: http://www.arubanetworks.com
Copyright (c) 2002-2011, Aruba Networks, Inc.
Compiled on 2011-04-14 at 19:29:17 PDT (build 27892) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 21294)
Built: 2009-05-11 16:02:29
Built by: p4build@re_client_21294
Switch uptime is 19 minutes 46 seconds
Supervisor Card
Processor XLS 204 (revision A1) with 891M bytes of memory.
32K bytes of non-volatile configuration memory.
256M bytes of Supervisor Card System flash (model=NAND 256MB).
Config File: default.cfg
Boot Partition: PARTITION 0
VLAN1 is up line protocol is up
Hardware is CPU Interface, Interface address is 00:0B:86:62:DC:60 (bia 00:0B:86: 62:DC:60)
Description: 802.1Q VLAN
Internet address is 192.168.1.150 255.255.255.0
Routing interface is enable, Forwarding mode is enable
Directed broadcast is disabled, BCMC Optimization disabled ProxyARP disabled Sup press ARP disabled
Encapsulation 802, loopback not set
MTU 1500 bytes
Last clearing of "show interface" counters 0 day 0 hr 19 min 46 sec
link status last changed 0 day 0 hr 14 min 26 sec
Proxy Arp is disabled for the Interface
switchrole:master
Configuration unchanged since last save
Crash information available.
Re: Controller 620 was reboot : Reboot Cause: Datapath timeout.
what is mean of Reboot Cause: Datapath timeout.
Moderator
I would strongly recommend you open a case with customer support. They can help you troubleshoot and determine the cause of the reboot. Without more information I would recommend you upgrade to 6.0.1.3 or higher. 6.0.1.3 fixed a bug where a datapath crash was causing controller reboots. I am not sure that is the issue you experienced but it would be a good thing to do.
