ArubaOS and Controllers
Controller Configuration/AP Installation
Is there a way to list all ap's when provisioning? We have 1000 ap's we are provisioning and currently we can only list 100 ap's at a time.
jp
Re: Controller Configuration/AP Installation
Through the GUI, there is no way today to list more than 100 APs at a time. Are you trying to provision them all at once, your do you want to do a search?
Its not really a big deal, I would just like to see all my ap's on one screen. Once I get them into their respected groups i can list them that way. Should be an easy fix for the Aruba engineers though.
