ArubaOS and Controllers
Moderator
Controller VIA configuration
Hello
I want to set up a controller to provide remote access to clients with the VIA client. I have been reading the manuals (version 5) and I am preety confident about most of it. However, I still have some doubts regarding IKE policies and IPSec crypto maps. Do any of you guys have an example of a working configuration?
Thanks a lot
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Re: Controller VIA configuration
You should not have to setup any crypto maps. The defaults are fine. The only gotcha that is not mentioned in the manual is that you have to setup an IKE shared secret in Configuration> Advanced Services> VPN Services> IKE shared secrets (it does not have to match anything, one just needs to be setup).
