don
Contributor I
Controller hostname
All, I've moved a local controller to a new building location and our hostnames right now reflect the building. I don't think changing the hostname would have any affect on its connectivity to the master, but it's not something that I've done before.
Any input appreciated, thanks.
Re: Controller hostname
It should not, the connection between master and local will be controlled by the PSK for the IPSec connection. If the controller's IP changed and you are using individual PSKs for each controller this will need to be updated on the master.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
