Custom captive portal
I am customizing the pages for a client captive portal but I haven't the aruba controller.
I know that the first page in "upload custom pages" is "Captive portal Login(top-level)" but what is the association with other pages, logout, welcome, etc.
All the pages are in the same directory when uploaded. Uploading a Welcome page or a login page just sets the Captive Portal Authentication profile settings for the Login as well as the Welcome page. Besides that, all pages are uploaded to the same directory.
Colin Joseph
Aruba Customer Engineering
I know that, but ¿whats the correspondence between welcome page and the logout page in controller and the options in "upload custom pages" in the configuration of the controller?
Re: Custom captive portal
You can modify the welcome page by selecting the appropriate profile first, then dropping the "Page Type:" box down on the Captive Portal upload screen and selecting "Captive Portal Welcome Page". AFAIK, you cant edit the logout popup page.
