ArubaOS and Controllers
DHCP and client-identifier
Guys,
using two controllers running 3.4.0.5, I'd like to see the client computers' dhcp-client-identifiers. I already tried setting the syslog's DHCP option to debug - but saw no names.
Any ideas?
Peter
Client Identifier
Guys,
Any ideas?
Peter
Did you do a packet capture to see if it is in there?
Re: DHCP and client-identifier
Haven't tried yet, shall I? I watched the syslog output for quite a while, observed a lot of boxes requesting IPs - but never saw any names...
Logs and Names
The logs on Aruba would only show things like the DHCP Discover, Offer, NAK, etc. It would not show the contents of the client-id, only the mac address and the IP address of that client. Any additional options would be seen in either some sort of packet capture or on the DHCP server if it logs that option.
So, since we're using the internal DHCP server, this is a clear fail. Thanks for making things clear.
Peter
DHCP Information
The question is what information specifically are you looking for in the DHCP server and how do you want to use it. The internal DHCP server on the Aruba controller is only recommended for use for guests and not enterprise use. The preferred route is to use an external full-featured DHCP server, which would have the options people want like dynamic DNS registration, etc. You can get information about what clients have received DHCP by using the "show ip dhcp binding" command:
(Aruba3600) #show ip dhcp binding
lease 1.1.1.254 {
starts Mon Dec 07 14:46:33 2009;
ends Tue Dec 08 14:46:33 2009;
tstp Tue Dec 08 14:46:33 2009;
binding state active;
next binding state free;
hardware ethernet 00:1a:1e:c0:24:0a;
uid "\001\000\032\036\300$\012";
lease 1.1.1.253 {
starts Mon Dec 07 15:18:34 2009;
ends Tue Dec 08 15:18:34 2009;
tstp Tue Dec 08 15:18:34 2009;
hardware ethernet 00:0b:86:c5:4c:c8;
uid "\001\000\013\206\305L\310";
