Contributor I
DHCP helper addresses
If I have more than one DHCP helper addresses for a VLAN, when will the second address be used? Just if the first server does not respond within a certain time, round robin or what?
Regards
Dirk
Helper Address
The broadcast will be sent to both addresses.
Colin Joseph
Aruba Customer Engineering
Contributor I
Re: DHCP helper addresses
Thank you very much.
Dirk
