ArubaOS and Controllers
Daylight Savings Issue
I am noticing an odd behavior on my 3200 controller today. It appears that the device does not want to leave summer-time mode on the clock. I have adjusted the summer-time settings, trying to reset the DST end date but with no success. It is currently configured with the same NTP server that my other network equipment and servers utilize. A SHOW CLOCK command displays the time as CDT, rather than the CST expected.
The main issue this presents is that the time reported in my syslog entries is incorrect.
Timezone
Chris,
What is the output of your "show clock timezone" and "show clock summer-time" commands?
Current
Here are the outputs you requested:
(Aruba3200) #show clock
Tue Nov 3 08:11:36 CDT 2009
(Aruba3200) #show clock timezone
clock timezone cst -6
(Aruba3200) #show clock summer-time
clock summer-time CDT recurring 2 sunday march 02:00 first sunday november 02:00 -5
As another test, I changed the summer-time setting to end on the last Sunday of October. This resulted in the clock switching to CST. Changing it back to the first Sunday of November reverted the time-zone to CDT. Could this be an artifact from the first Sunday being the 1st of the month?
Support Case
Chris,
Open a support case. I don't think that should happen.
Re: Daylight Savings Issue
Sounds like it. It may be looking for the first Sunday after a week begins on Monday. If you change the date to 11/9 and it works then it's certainly the case. Please open a ticket with support.
Thx.
