ArubaOS and Controllers
Debuging Connection issues
All of the sudden, I'm having issues with getting new PCs to connect to our Corporate SSID. Issue looks to be 802.1x authentication failures, but Macs and PC that were already configured aren’t having any issues, so it doesn’t look to be an 802.1x configuration issue. What are some good debug commands to watch the authentication process? Thanks.
Re: Debuging Connection issues
Turn on user debugging.
config t
logging level debug user
show log user 50
What are you using as the authentication server?
What is the encryption?
What types of clients are these?
Do they already trust the CA that issued the radius server certificate? For the PCS that are part of the domain, try a "gpupdate" on the commandline to get them to do that automatically.
config t
show log user 50
Thanks. Just what I was looking for.
1. LDAP
2. PEAP-GTC
3. 64bit Win 7
4. Yes, they trust the CA Root
Doing some more troubleshooting, it might be an issue with the PEAP-GTC plugin. We are really having issues getting it to install.
