ArubaOS and Controllers
Deleting Firmware from a Partition
Does anyone know the command for deleting and older version of firmware from a partition on a controller?
Re: Deleting Firmware from a Partition
You can usually just copy the firmware version of the partition you are running on to the unused partition. I'm not sure if you can delete the firmware from the running AOS, you would likely have to go into the CPBoot.
Copying the active partition to the unused partition is:
copy system partition X Y
where X is the active and Y is the inactive.
Jerrod Howard
