ArubaOS and Controllers
Contributor II
EAP Offload and Machine Auth
When I take a working 802.1x profile and enable "termination" / eap-peap / eap-mschap for Eap Offload to the controller, users continue to authenticat fine but workstations do not. The workstations were authenticating OK before doing the offload. What am I missing?
The IAS log reports as the error:
Reason = Authentication was not successful because an unknown user name or incorrect password was used.
b
-b
www.apextechgroup.com
EAP Offload - No Machine Authentication.
EAP Offload, or Termination, does not work with Machine Authentication. You will need an external radius server with a Valid Certificate for machine authentication to work.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: EAP Offload and Machine Auth
bhubert,
thats a known issue with IAS, termination on the Aruba controller and machine auth. I have tested this on another RADIUS server and it works. I dont want to say which RADIUS server, but it is a well-known $25B company that just announced a 322 Terrabit router... :)
Contributor II
Thanks gents. Has it been tested with Win2k8's implementation of RADIUS (NPS)? Is there something that I can 'read' that explains why this doesn't work?
-b
From the inception
It has never worked Microsoft IAS and that is not going to change any time soon. It would require a great deal of work that was never attempted in the past, and it is less likely as time goes by.
