ArubaOS and Controllers
ESI forwarding and tunnel mode
Is ESI forwarding limited to tunnel mode, or can it be used in split-tunnel as well? Trying to use this on some RAPs and it doesn't work if the VAP is in split-tunnel.
Re: ESI forwarding and tunnel mode
Darn, I thought this would be an easy one.
