ArubaOS and Controllers
Occasional Contributor I
Easy way to copy AP Group
I want to create several AP groups, where the only difference is the VLAN.
Is there an easy way to create a dozen AP groups which only differ by the VLAN (and name, obviously) using either the CLI or the web interface?
We are currently running 5.0.x because of a bug in IPV6 in 6.x.
Thanks!
Re: Easy way to copy AP Group
conf t
ap-group new-group
clone old-group
Thanks! That did it!
Is there an easy way to move a group of APs into a different group?
The provisioning page is the best way.
