ArubaOS and Controllers
Frequent Contributor II
Firewall and Port Blocking
Is there an actual firewall log that I can look at to see if any particular ports or destination IP's are being blocked? I'm using a 3200 controller.
Network Engineer | Airhead | Titus 3:5
Re: Firewall and Port Blocking
For each user that is in the system, you can type "show datapath session table " on the commandline to see if any traffic has the "D" flag, which means deny.
