ArubaOS and Controllers
Occasional Contributor I
GTC Plug-in Supplicant removal
new Aruba released gtc plug-in software 32 bit and 64 bit is working on windows7..
where it is installed on xp systems , leads to network driver crash... and reinstalling to xp version plug-in is also not working on these particular systems.
Anyone have come across any useful tool to remove this plug-in and install with xp version?
Thanks in Adv
RK
Re: GTC Plug-in Supplicant removal
It should be under add/remove programs.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
